Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Volume button is loose
I replaced the housing on my iphone 7 but the volume up button is sort of loose, and it doesnt stick out properly. I believe this is because the screw hole for the bracket is a tiny bit extruded, like half a milimeter, but im not sure if that actually is the problem.
Add a comment
1 Answer
Did you replace the gasket on the buttons? If its loose either the gasket isn’t sticky enough to hold on the frame or possibly you used the wrong screw in the piece that holds it in.
Add a comment
Add your answer
Simon Kapicka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 107
