Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87 Questions View all
Which video guide to replace 2019 MBP right speaker?
My right speaker has gone bad and I’ve ordered a new one from ifixit. (Never had the popping problem that others have reported…)
(Right speaker rattles, sounds quieter and bassy, while the left speaker is still clear. This just started about to weeks ago.)
QUESTION: Which ifixit video guide should I use for replacing the speaker?
Add a comment
1 Answer
Chosen Solution
Follow this guide up to step 15, then find where the right speaker is located. Use some Isopropyl (Rubbing) Alcohol to soften the adhesive holding the speaker in place, then disconnect the speaker connector and remove the speaker. After cleaning the spot down and making sure the isopropyl alcohol has dried, take the plastic off of the speaker adhesive, then stick the replacement speaker down. Follow the guide from step 15 backwards to reconnect the battery.
MacBook Pro 15" Retina (Mid 2018-2019) Right Speaker Image
Product
$24.99
Score 1
1 Comment:
Also review this guide MacBook Pro 15 2016-2017 Speaker Replacement which is similar.
by
Add a comment
Add your answer
Chad Gagnon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 106
