The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
Load noise while printing and print is barely visible
While my printer is printing we hear a very load noise almost as if it is struggling or grinding. Also, when a page is printed, it's not clear seems as if it doesn't print properly and the ink is almost full so should print clearly. Thank you for any help.
Add a comment
1 Answer
Those are two different issues. First the low ink issue. The print heads can get clogged and there is a clean printhead function. repeat several times until you get good ink.
second one is likely a plastic gear that you will need to find and replace.
Add a comment
Add your answer
Krystal Torres will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 204
