Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
39 Questions View all
Charging only on low wattage charges, and only for a few minutes
This ipad is charging only on low wattage chargers and only for a few minutes before it displays “ipad not charging.” A new battery has already been tried, as well as several resets and updates. I'm not 100% convinced that this is a charhing pirt issue but I dont even know anymore, any suggestions?
1 Comment:
Did you even try changing the charging cable?
I feel it's not original cable that you are using to charge your iPad.
by
Add a comment
1 Answer
it could be the wall wort or cable is damaged and I hope that is the case. if ot those than the port probably needs to be replaced or you can a bad resistor on the charging circuit.
Add a comment
Add your answer
Garrett Chism will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 81
