Freezer semi cold but fridge warm
Hopefully someone can figure this out with me. My GE GSH25JFXB model number fridge suddenly stopped cooling correctly. I have at this moment pulled out the back freezer panel and here is my findings. Freezer cool’s and has no ice build up on the coils as I replaced defrost heater a couple of years ago so all is good there. The bottom of the freezer is cold and some cool air makes it over to the fridge area but not enough to keep everything cold.
It would appear that the evaporator fan or the fan that pulls the cold air up from the evaporator and to the upper part of the freezer and into the fridge area is not working. I tested it by having the door open and shutting off the light switch to fool it into thinking the door was closed and the fan came on for a moment but then turned back off.
So I know it’s somehow a problem with the fan or it’s thermostat’s but not positive given the trouble shooting from other’s. I checked the evaporator fan blades and the blades move freely with no problem. So wondering if it’s the thermostat def but the troubleshooting always seem to point out ice build up for that and I don’t have any ice buildup or is it a possible control board issue? So there is my problem any help from someone experienced in this area would make my day…
