Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
GPS disfunction after replacing display.
Hi.
After successfully replacing the broken display of my iPhone 3GS my GPS doesn't workt anymore.
Did i do something wrong?
regards,
Max
Score 1
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
check that you didn't bump connector 6 off..it's only a tiny round connection for wifi/gps and difficult to notice it not connected.
Score 2
Comments:
connector 6 is still connected.
by
If the WiFi works perfect then #6 is connected OK. GPS will not work correctly if you have installed iPad baseband 6.15.00, tap Settings App>General>About>near bottom, modem firmware #.
by
Wifi works ok. My moden firmware is 05.15.05.
by
try resetting network settings.... settings/general/reset/network settings.
by
reset network settings doesn't work.
by
Add a comment
Hello
I have the exact problem.... i am trying 5 days to solve i tryied everything....
does anybody knows something? or i have to change the entire motherboard??????
Add a comment
Hello I have the same probleme.Please help
Add a comment
Add your answer
info will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 660
