Turn signals not working
My turn signals aren’t working on my 2001 Cherokee. I replaced 2 bulbs and checked all the rest. When I force the right signal it blinks once then nothing
@lbrannock11 check the blinker relay because that could be what is causing this. Not a terribly complicated job. This video makes a pretty good job of showing you how to replace it.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 382
2 Comments
Changing the relay lit up the signals so I can manually make them work but it stopped my hazards from working. This is as far as I can go as I can’t take off the steering wheel
by Lisa Brannock
@lbrannock11 you made sure that you have the proper bulbs in your lights? Some of the multi filament lights can cause this if they are the wrong type.
by oldturkey03
