Hi @jeffthewhiteguy ,
What is the model number of the TV?
Was the TV on at the time of the storm? You may be unlucky in that both the mainboard and the power board have been damaged.
The screen backlights turning on when the power is connected to the TV is not a good sign.
Normally with Samsung TVs (and most others) when the power is first connected the TV’s LED Standby power light turns on and that is all.
A quick backlight test with some Samsung TVs to make sure that they’re working OK and that the power board is working to some degree (enough to power the backlights anyway) is to disconnect the mainboard - power board cable from the power board and connect the power. The backlights should turn on because the signal from the mainboard that stops this from happening when power is first connected is missing i.e. cable disconnected.
Secondly with all boards connected and the power is connected to the TV, the Standby light is turned on by the mainboard when it receives the Standby voltage signal from the power board, indicating that power is available. When the TV is turned on by the remote (or the TV power button), the mainboard commences switch on by sending a signal to turn the power board full on so that all the necessary power is then available.
You need to check if the PS_On voltage signal is there all the time on the power board when it shouldn’t be when the TV is in Standby mode or if the Standby voltage signal (STBY) is there. The STBY voltage value is marked on the power board somewhere - either near the cable connector for the mainboard cable or perhaps a link on the board itself.
Knowing the power board model number (possibly BN44-??????? - or the TV model model number to find the power board) will help to hopefully find the schematic for the power board so that more detailed diagnostic testing can be done. Mainboard schematics aren’t generally available or not that I’ve found anyway.
