Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
355 Questions View all
Ear piece not woking after screen replacement
I recently replaced my front screen on my xs max iPhone and everything works fine except the earpiece. The loud speaker works but not when you want a private conversation. I have seen posts about it but not how to fix it. Could someone tell me exactly what it is I need to do? Thank you
Add a comment
1 Answer
Hi ,
The earspeaker is on top of the screen and needs to be switched from one screen to the other.
It may be that it is not correctly plugged in or the cable the speaker is soldered to was damaged during the replacement.
Good news is if the part it damaged it should not be expensive for a replacement.
The bad news is on the part there is also a sensor called the proximity sensor which plays a role in the faceid circuit. If the proxi sensor is replaced, face ID wont work any more. It will only work with the original proxi.
The proxi can be transfered from one flex cable to anothet one, but requires micro soldering.
That being said, everything else should work just fine after replacing that flex cable.
I hope this helps, let me know if you have any other questions
Add a comment
Add your answer
Jennifer Hughes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 52
