Need help with fixing dead keys on Roland FP-30
Hi all,
I have little more than a year old Roland FP-30 that hasn't been used for a few months. Now I see that it has lot of dead keys. I tried opening it up, cleaning with isopropyl alcohol (91%). However, only a few keys sprang back to life.
I tried again next day but still nothing worked.
I also noticed that the rubber contact pads are little longer (have three holes with 2 contacts). I am having trouble finding them online. I reached out to Roland, but they asked me to go to repair shops that charge $150/hr. The repair along with uber will cost me >$300. Does anyone know where can I find the rubber contact pads for FP-30
What else can i try to fix it on my own? Cleaning again does not work and i dont think the pads are an issue since the same contact pad works elsewhere.
any help is appreciated
Can you take a picture? Adding images to an existing question
by Andrew S
Hi,
Did you also clean the board that the rubber contacts come into contact with when pressed, you didn't say?
by jayeff
Thanks for your response. Yes, i tried cleaning the board and rubber pads but nothing works. I am thinking the problem is something else.
I transported the piano during house move and that might have loosened up a wire?
But i am not sure how to open it up and where to even look.
Since all the keys are grouped and on the higher end of the keyboard my hypothesis is that it is some other problem.
by shadow hunter
Hi, did you manage to find a solution? I have the same problem
by Axel MN
