Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
phone does not start properly after replacing rear panel and battery
I followed the 3GS replace rear panel / replace battery guide.
Once complete I tried to start, nothing happened.
I connected to laptop via usb. Phone screen is illuminated and apple logo appears for approximately 4 seconds, the switch off, and the same over again.
I assume without being aware I made a mistake in re-assembly, or even broke something during the action.
Does someone can advise what component / cable / connector might be affected?
Obviously the screen works, and something electrical works.
Thanks
Score -1
Add a comment
1 Answer
Most Helpful Answer
1st I would just try to charge the battery thru wall outlet. Give it a couple of hours. Sometimes new batteries need to be charged.
Score 2
1 Comment:
check the screw under and next to the "do not remove" sticker, they keep the motherboard in contact with the battery terminals.
by
Add a comment
Add your answer
Danyel Ceccaldi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 519
