Repair guides, disassembly, and troubleshooting information for the 7th-generation Apple iPad, available in Wi-Fi and cellular versions with 32 or 128 GB of storage. Released in September 2019. Identified by model numbers A2197, A2200, or A2198.
iPad Failed During Software Update
Hey guys,
I had a customer bring in an iPad 7 updating OTA to 14.7.1. During the update, it was charging and the customer left and came back to it to find a black screen. iTunes will not work and of course Apple told him to kick rocks. We have both tried various software to reflash it, including 3U Tools, but we are not having any luck.
In my attempts, 3U Tools would start flashing the firmware, and when it tried booting into recovery mode from DFU mode it would never succeed. I even let it run the 10 minute timer to see if it would eventually work. Just to amuse myself, I measured its power draw and it intermittently draws 0.00, 0.09, and 0.99 amps before returning to zero and cycling through those numbers.
At this point I’ve almost completely ruled out software, so what component do we think it is? Tristar, or perhaps NAND issues?
I’d appreciate any pointers or direction. Thanks guys.
Add a comment
1 Answer
Chosen Solution
Does it take proper charging voltage? If yes it's most probably a faulty NAND or NAND Power line. But as your customer said it was plugged in immediately points to Tristar so i would first take a look at the charging circuit. Do let me know what do you find, It would be easier if you had an ICC pro. It would’ve told you if its a tristar fault without opening the iPad.
Add a comment
Add your answer
FiftyFixes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 313
