Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
no GSM signal, only week 3G signal -100db
I fell on my iPhone and i shattered the screen, after a complete tear down and screen replacement, i have problems with my GSM Signal
it only works on 3G with very low strength -100db, and when i hold it "Death Grip" it looses all the signal, when i turn off 3G, it finds Edge for one second then NO Service appears.
Wifi and GPS signal are strong and fine
what i did so far:
The blue capacitor beside the battery connector is there and working fine, I rebuilt it twice, changed the Sim card, did a network restore, iOS update, the speakers "3G Antenna" metal connectors to the body are all there
What i doubt :
The Chases is a little bent in the middle due to the fall, and i am missing a rubber thing on the top of the phone over the camera "lost it while replacing the screen"
I would really appreciate it if anyone can help out
Add a comment
Im with the same problem... Already changed the Cellular antenna and nothing
Add a comment
I replaced my midframe and I consistently get 1-2 bars less than my wife's stock iPhone 4. Blue inductor is present. I cleaned the cellular antenna connector wire and socket with alcohol and it still get's 10-15dBm lower. I do know when I replaced the speaker/antenna assembly, 2 of the 4 prongs broke off, but I thought they were for EMI purposes only? I'm thinking the blue anodized finish of my midframe is causing a connection problem, perhaps at the brass tab/screw to the right of the assembly (opposite the connector to the board). I guess I'll replace the GSM antenna assembly next as well as sand off the anodized finish of the frame where the screw is that I was speaking of.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,441
