Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2921 Questions View all
Dust in camera lens, how to proceed
I have found a partial of dust which is affecting my new 4S camera.
Is there an easy way to remove it myself, I.e releasing back cover or is the lens sealed?
Many Thanks.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
iPhone 4S Teardown
this is the tear down from here, seems that if it is the back camera it will be relatively easy as it is accessible with removing just the back panel, I guess it depends exactly where the dust is.
You may need a special pentalobe screw driver if you don't have one and your phone has those screws these should be relatively cheap to acquire.
Score 3
Add a comment
I have the same problem.
Will it void the warranty if I open it up?
Thank you in advance!
Comments:
Add a comment
just open the screw's at the bottom , open the back cover ....... blow air or clean it wit a dry cloth .... your problem is solved ... but this is not permanent ...... the dust keeps on coming .....
Comments:
what is the permanent solution?
by
Add a comment
Add your answer
krazeswift will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 22
All Time: 5,360
