Replaced logic board now left fan on full speed
Hey guys,
Replaced my logic board with the touch ID button as well which came with the board. Now my left fan is on full speed.
What I tried:
- Reset SMC
- Mac fan control (did not even change the sound or speed of the left fan, cranked up the right fan and I could hear it)
- Opened the whole thing again checking for connections and making sure they were plugged in correctly and properly, everything was perfect. (Visually checked to see if the right fan is spin which it does)
Any help would be much appreciated.
3 Comments
Why did you replace the logic board?
I would run the onboard diagnostics to see what it shows. Restart your system and press the D key
Reference: Mac startup key combinations
by Dan
Hey, thanks for replying.
I replaced it due to my old one died out of the blue and a friend had a broken screen mac sitting around same model.
I just ran the diagnostics and it came back saying:
There maybe be an issue with the fan.
Reference Code: PPF004
Additional Ref Code: PPF003
by Midge
P.S I looked up the code and people are saying I should replace the fan, it was running fine before the board died so could it be something else? If I replace the fan and the problem is still there then what else can I do?
by Midge
