Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
79 Questions View all
MacBook Pro shuts off upon disconnecting charger, works with charger
Got this laptop July 2020, had a beer spill in March 2021 resulting in a keyboard replacement (functioned perfectly after keyboard got replaced) and then one day I just started getting this issue, laptop works flawless while on charge but once charger is removed, it shuts off with no sign of life. SMC reset did not work, took it to a repair shop and they said it’s a motherboard issue and will cost $250 (don’t believe that it is a motherboard issue after this coconut battery result):
Since getting the keyboard replaced, i could hear a sort of “tapping” sound everytime i shook my laptop (assumed it was the battery as the glue had to be removed to replace the keyboard). I slightly suspect that the battery’s connection to the logic board has come undone and that’s why this is occurring, but I’d appreciate any insight.
Thanks in advance!!
Score 1
Add a comment
1 Answer
It should be the battery. If you can hear a sound from the inside when you shake the device that certainly says that the battery is not glued in which as you said increases the risk of it being disconnected. However, the battery could also just be dead, if it is left uncharged for too long lithium batteries can completely die to the point where they cannot be charged which is unfortunate. I would think a new battery should fix it completely, but before trying a new battery try and connect the battery again. Hope this helps!
Add a comment
Add your answer
Arman will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 6
All Time: 136
