Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
How to fit that plastic bit inside the LCD assembly?
Just bought a screen but it doesn’t come with the transparent plastic bit that fits underneath the notch.
There is a hook in that plastic part (circled in blue).
Also, the LCD assembly that I received has some kind of little plastic bit inside where the earpiece fits (circled in red). It prevents the earpiece (circled in green) from fitting into its normal place.
Is there a way I can fit this? Am I supposed to unglue the metal frame that is all around the screen assembly, for it to fit?
Will anything bad happen if I just cut off that little hook?
Add a comment
1 Answer
Chosen Solution
As long as the plastic doesn’t warp too much and prevent the FaceID sensors from working, it should be fine to get rid of that little part. No need to glue the plastic down but simply put the sensors, camera, and speaker on top of it and screw it all down. Might be a little tricky but take your time and don’t screw anything in too much if there’s any resistance and the sensors aren’t all flush with the screen.
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 85
