Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Home button doesn’t vibrate but Touch ID works
I recently replaced the screen in an IPhone 8 Plus and the home button isn’t working but the Touch ID still functions. I’ve tried loosening the screws. It’s an ifixit screen so I doubt that’s the problem.
Add a comment
1 Answer
Chosen Solution
It doesn’t matter where you purchased the screen. If the shortest flex at the bottom gets a micro tear when installing it will produce the symptoms you are facing.
You will need to try a replacement screen. If the home button still doesn’t work it will most likely be a damaged turtle IC on the home button assembly.
Score 1
Add a comment
Add your answer
Bea Williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 7
All Time: 109
