Switches on and off randomly
I have an iPhone 3GS which keeps shutting off and switching back on randomly. I thought this may be a battery issue ie not holding charge, but I have just replaced the battery and it keeps doing the same thing.
It does not appear to matter how much charge is in the phone it will just switch off and then reboot on again.
HELP !!!!!!!!!!
is there any pattern to the turning off? launching apps, playing car games? has it been having any problems with power button?
by pollytintop
No, it does not appear to have any pattern. When I changed the battery and switched it on it continually switched on and off for a while and then I recharged it and it seemed to calm it down although still does it. I dont think I have been having problems with power button - is that worth replacing?
by I Morgan
No. I think this isn't battery. I'm wondering whether your power button is the culprit. Try disconnecting it from logicboard.. No 5?(square connector). You'll be able to power on via USB but then it should turn on with home after that. See if it improves things.. May just need a cleaning.
by pollytintop
