The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Could a faulty LVDS cable cause no backlight?
I've recently replaced my laptop logic board as there was a number of issues with the early 2015 MacBook like keyboard backlight not working and fans running full speed, but the main reason being the backlight not working. I can see the LCD working when I shine a flashlight through it and works with an external display.
After logic board replacement, the laptop nearly works fine except for the display backlight.
Could a faulty LVDS cable be a possible issue?
1 Comment
After disconnecting the battery, disconnect the display cable (its not LVDS in the retinas - now using eDP/iDP signaling, just call it what it is). Take a picture of the cable end so we can see the gold contacts and post it here for us to see Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
Yes it can, the power for the backlight runs through the eDP/iDP cable. I’ll say it’s pretty uncommon, but it’s possible. Since you already replaced the logic board, the only other possibilities is the eDP/iDP cable or the backlight itself and the eDP/iDP is a lot less expensive to replace than the screen assembly.
Score 2
1 Comment:
Update! Turns out it was a faulty eDP/iDP cable. Swapped it out and tada! Works perfectly now. Phewww saved!!!
by
Add a comment
Add your answer
Ahkoo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 316
