Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
Is this micro scratch?
After successful attempt on removing the anti-glare coating on the retina MacBook Pro screen using Listerine and only using the microfibre cloth and clean it just after removing all the left behind anti glare but when the screen dry off after the cleaning, I can see the screen not shiny like a normal screen it see like a rough texture on the screen but it’s not rough when you touch it. Does anybody maybe this is just anti reflectice that just won’t come off or it are micro scratches? If so how it happened because I’m only using the microfibre cloth to clean it up?
Add a comment
1 Answer
Chosen Solution
I’m suspecting you haven’t fully cleaned off the coatings.
This also explains your other issue! Dead pixel or stuck pixel on retina screen? As the Listerine seeped under the screen along the edge wetting the defuser sheets MacBook Pro Retina Display Teardown checkout step 12
Score 1
Add a comment
Add your answer
admwitchy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 325
