Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Turn off switch control with broken home button
So while trying to turn on voice control i accidentally turned on switch control and messed up a bit in the settings , I can't move even my home screen cause of switch control and my fingerprint won't work , I wanna know if there could be a way to turn it off without using the home button because mine doesn't work , I tried powering it off but I need to slide on the screen and it won't let me , Help
Score 2
Add a comment
Hi @nicoley
Please navigate to Settings > General > Accessibility > Switch Control and turn the setting on or off.
Switch Control can also be deactivated from iTunes:
  1. Connect your iPhone, iPad, or iPod touch to any computer with iTunes installed.
  2. In iTunes, select your device.
  3. From the Summary pane, click Configure Accessibility in the Options section at the bottom.
  4. Select the feature that you want to use and click OK.
2 Comments:
can you download iTunes on a non apple pc
by
@nicoley You can run iTunes on any Mac or Windows 10 PC. Simply Google for "iTunes" and Apple's download page should be the first result.
by
Add a comment
If you have no response on the screen and you home button is not working, plug it into the a computer with your Itunes account on it. Then just restore to a backup from before you flipped the settings. That should fix your issue.
Add a comment
Add your answer
Nicole will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 32
All Time: 2,311
