Looking for component replacement
I bought a gtx 1070 and gave it to my lil bro to install in pc, but he weirdly put the 6 pins before installing the gpu in the pci port, when he heard the frying sound( instantly removed power) but the damage is done yet we tested the card still work, anyway i tore the card to find the fried component that still work but sure not for long time
Is there a way to fix it?
Add a comment
Most Helpful Answer
can you take a picture from the side instead of top down? it looks like a coil. which is VERY easily replaced with a little soldering knowledge.
thankfully it doesnt look like theres too many sensitive components that could be damaged by replacing this. ( some times with hot air you can damage surrounding SMD components)
the hardest part is going to finding a picture or schematics to figure out what coil it is that needs to be replaced.
you can also send this off to a reputable repair shop so they can figure out.
Score 1
1 Comment:
Ill make other pictures soon, im happy there still chance
by
Add a comment
It is an inductor. I would use it as long as you can. If it disconnects no harm is done. The card just stop working and then you can have it repaired. Odds are it is usable.
1 Comment:
I used it for few days, play small games ok but games like rdr 2 or ac valhalla it sudden quit after few minutes sometime more
Ithink when the gpu go heavy it need more power n that cause the quit maybe?
by
Add a comment
This one is from the same graphic card fro the internet
Add a comment
Add your answer
Nopar Despar will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 219
