Why is paper feed not working on HP deskjet 2600
why is paper feed not working on HP deskjet 2600
I had the same problem with a hp 3600, and the motor had nothing to do because I heard it running, I just cleaned the rollers that are inside of the paper feeder, I used cotton tips with alcohol.
not enough info about symptoms, but I would check for paper jam. Otherwise, add more info.
when a paper feed is attempted, the first thing that happens is a motor starts running. If you don’t hear that, then you have a motor or a control problem. If a motor is running and no paper is feeding then you have a mechanical issue, bad gears or rollers.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,142
1 Comment
There is no paper jam, no foreign objects paper is just not feeding, have seen reports of gear splitting on feed rod but cannot find it.
by texteditor
