Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Any way to patch dents/marks in unibody
At this point, by the place the laptop's display is showing it's age because it has chips of aluminum that look chipped
Is there any way to patch this or does the unibody have to be replaced outright
BTW, there is a slight dent i don't care about too much, you can't see it unless you look in light on a angle
Score 2
Add a comment
1 Answer
Chosen Solution
If you've got the missing chunks, super glue does alright on metals. The dent MAY be able to be pulled via a suction cup or some similar utility...if you need to fill the dents you may be able to find colored car body filler, though I'm personally a fan of Bondo and paint :D. (Not that I've used it for this particular application mind you...)
Score 2
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,229
