Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Questions View all
Home button touch ID swap temp to original
I know the MB and Home Button are married and that touch ID will NOT work if the home button is replaced. I misplaced my original HB so I got a new one. My question is: If I install the new one and later find my old one and put the original back in will the touch ID then work again? Or does swaping it, and then powering it on with a replacement then permanently disable that feature even if replaced back?
1 Comment:
Anyone able to help with this?
by
Add a comment
1 Answer
Hey,
Replacing the old home button later on will just work fine until and unless you damage the button itself. Using a temporary replacement button would not hurt.
Cheers :D
Add a comment
Add your answer
TYSON PELTZ will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 25
