A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Spots on screen Windows 10
At times the computer will show spots on the monitor then either freezes or resets itself. Not sure if this would be a graphics card issue or rams? Any advise would be greatly appreciated! My computer specs are ;
Core™ i7-9700K Processor (8x 3.60GHz/12MB L3 Cache)Processor DDR4-3200 XPG D41 RGB MemoryVideo CardNVIDIA GeForce RTX 2070 - 8GB (GDDR6) NVIDIA RTX Graphic CardsMotherboardASUS TUF Z390(Wi-Fi) -- RGB, 802.11ac WiFi, USB 3.1 (6 Rear, 4 Front), ASUS TUF ProtectionPower Supply850 Watt Thermaltake Toughpower Grand RGB 850W 80 PLUS Gold, Full ModularAdvance Cabling OptionsStandard Default CablesPrimary Hard Drive 500GB WD Blue SSDData Hard Drive4 TB Seagate Barracuda PRO Hard Drive -- 128MB Cache, 7200RPM, 6.0Gb/s - Single DriveSound Card3D Premium Surround Sound Onboard Network Card Onboard LAN Network
Add a comment
Most Helpful Answer
  1. try and inspect and reseat all connectors for video.
  2. try using a different monitor \ cables
  3. remove the power cord from your pc and try to reseat your ram and video card ( if applicable)
  4. if you have multiple sticks of ram try removing them all except one and see if that changes anything.
  5. try using other ports on the video card.
Score 1
1 Comment:
I will be sure to give those a try as well! Thank you!
by
Add a comment
Hi,
Some things to check:
i). Check that you have the latest video drivers installed.
ii). Try using the Intel GPU that is integrated with the CPU, instead of the Nvidia GPU and check if the problem still occurs. If it doesn’t then there may be a problem with the Nvidia GPU card. You will have to connect the monitor to the motherboard’s HDMI or DP port.
You may have to enable the Intel GPU in BIOS. I’m not sure and the user manual doesn’t show it but go to BIOS > Advanced > System Agent Configuration and check that the Initiate graphics adapter setting is set to iGPU. Save the changes and exit.
iii). Perform a Win 10 memory test to check if the memory is OK
iv) Check in Event Viewer for any Critical, Error or Warning events that are logged at the time that the PC resets that may give a clue as to what is happening. To get to Event Viewer, press the Win key + x key (both together) and then click on the Event Viewer link. If there are entries that occur at the same time, search online using the Event ID and source to find out what they mean.
Score 1
1 Comment:
Thank you! in such a quick response! I will surely try that tonight! I appreciate the tip and give an update to see if it works!
by
Add a comment
Add your answer
jyuen82 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 63
