Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Tri-point tip sizes available?
On the page for replacing the battery in my mid-2012 13” macbook pro,
MacBook Pro 13" Unibody Mid 2012 Battery Replacement
it tells me I need a Y0 tri-point screwdriver. In Step 5 it states:
  • One 5.6 mm Tri-point screw
  • One 13 mm Tri-point screw
Are those measurements for the screw length or are Y0 tri-points available in assorted sizes OR are Y0, Y00, etc. each a fixed size designation? Researching it online is not definitive, and most I find are tri-wing vs tri-point.
I did find your Mako Driver Kit - 64 Precision Bits listing Y000, Y00, Y0 and Y1.
Add a comment
1 Answer
Most Helpful Answer
The size is the length of the screw. You need a Tri-point Y0 Screwdriver screw driver or bit if you are using the driver kit.
Score 2
Add a comment
Add your answer
Bill Friesen will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,201
