Displays Dell logo on laptop but no display post logo
When I press the power button, the dell logo shows on the laptop, then nothing.
But, when I plug an external monitor into the laptop, the device is actually booting into windows and is functional through the external monitor. In settings the only screen recognised is the external monitor.
I know the laptop screen is working as it shows the dell icon on boot but nothing else.
Also if I press the power button while holding down D it runs the colour test on the laptop screen it works fine, but even booting into the bios does not display in the laptop, only the logo + colour test
Can anyone help? Thanks
Add a comment
Hi,
Try a power refresh in case the BIOS has glitched and is only connecting to the external monitor.
Turn off the laptop if on and disconnect the charger (if connected).
Disconnect the main battery from the motherboard. You don’t have to remove it, just unplug it.
Remove the coin cell battery from the motherboard. Note the orientation of the battery before removing it, so that you will reinsert it the correct way later. Usually it is +ve on top.
Here’s the service manual for the laptop. Go to p.20 and p.22 to view the necessary pre-requisite steps and then the procedures to disconnect the main battery and to remove the coin cell battery
Press and hold the laptop’s Power On button for a full 15 seconds to reset the BIOS back to factory default, then release it.
Reinsert the coin cell battery.
Reconnect the main battery and reassemble the laptop.
Connect the charger and turn on the laptop and check if it is OK.
If it is then there may be a message regarding the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time has been corrected the message won’t show again the next time that the laptop is started.
Also any user defined settings that were altered in BIOS to suit your particular operating requirements will have to be set again.
Add a comment
I have a refurbished 7490 and after pressing the power button some lights came on and the fan would spin but the display remained dark, moments later dark and quiet. I tried many things including external monitors, disconnecting everything ssd, ram, wireless, keyboard, etc. and couldn't get a POST display, or when main display disconnected on an external display. Disassembled and probed voltage test points - all seemed normal. Removed and inspected main board (all except disconnecting CMOS battery). somewhere some how (possibly holding control and escape on boot?) it booted enough for me to install a critical stability BIOS patch. System was used daily and was stable for a whole month.
It is somewhat murky but likely crashed while in use which seems like a different issue. (Not my laptop, I just bought it and am responsible for its service)
It appeared to be up to its no boot antics. After it sat for 3 nagging weeks I tried again and it booted. (when it wouldn't boot there were IC's that would warm up so it was consuming power. surfing through the BIOS logs I found "Alert! BIOS Recovery Triggered." I also enabled BIOS Auto Recovery and extended the fast boot from minimal to thorough.
I recommend folks check manufacturer service information. it is surprising the number and frequency of critical patches that there are. Disappointed in the refurbish company as some of these critical patches are a year old.
Void the "warranty", take ownership, learn how things work, you'll be happier.
Add a comment
Add your answer
chris daly will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 10
Past 30 Days: 27
All Time: 2,476
