4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
iPhone SE: battery charging only 13% and restarting
Hello,
I dropped my iphone SE (first generation) from a considerable height. It was in a silicone case that popped out after the hit. As a result my screen was damaged beyond repair. I ordered a new one and replace it, but then I noticed that the battery only charges to 3-4%, so it was constantly charging. I thought the reason was the battery, so I bought a new one. After the replacement the problem remained, the battery is charged only to 13% and the phone restarts shortly after opening apps. Powered off the phone and cleaned the plug with rubbing alcohol, nothing changed.
My question is: could this be due to the charging port or is it probably some other hardware problem? If not the charging port, what could be the reason?
I love my phone very much because it is small and I am attached to it. I want to know if there is any chance to save it or it is not worth it :(.
Thank you in advance :)
Add a comment
1 Answer
Best course of action is to replace the charge port and the battery, due to the charge port most likely being the cause. The battery is just to be sure. The links are included at the end of my answer, as well as the guides. Happy Fixing! TAG2YT | iPhone SE (1st Gen) Battery iPhone SE (1st Gen) Lightning Connector and Headphone Jack | And here are the guides: iPhone SE Battery Replacement iPhone SE Lightning Connector Replacement
iPhone SE (1st Gen) Lightning Connector and Headphone Jack Image
Product
$19.99
iPhone SE (1st Gen) Battery Image
Product
$29.99
iPhone SE Battery Image
Guide
Difficulty:
Moderate
40 minutes - 1 hour
iPhone SE Lightning Connector Image
Guide
Difficulty:
Moderate
50 minutes - 3 hours
3 Comments:
Than you for the fast reply!
I have changed the battery already, but the problem reminded.
For this reason I was wondering if it is due to the charge port or something more complicated that will be very expencive to fix.
by
Like one of the charging components on the logic board for example.
by
Replacing the charging port would be the best thing, being as it is likely the suspect.
by
Add a comment
Add your answer
Zeld Ina will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 6
All Time: 52
