The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer won't start-No F01 Code
The Dryer does not have power going to it. Checked outlet, it has power so itisn’t a power outlet issue. Fuses are all in good shape. Repairman suggested control panel issue, but couldn’t replace due to his company not carrying the panels.
In all other cases for this dryer, I have seen changing the control panel as a solution to the F01 error code, not for a dryer that won’t start, period. Does this seem like a solution, or does this seem like the dryer is just done. I just don’t want to pay 150 for a control panel if it likely won’t do the trick!
1 Comment:
Hi,
What is the model number of the dryer?
by
Add a comment
1 Answer
If you have had a power outage or surge recently this is most likely the answer to the problem.
If this is the case the answer is to buy the new control panel.
Add a comment
Add your answer
Jillian Pastick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,041
