Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Why are there vertical blue lines and I cannot login
I have vertical blue lines on my monitor. When I restart I get the same thing and any text or graphics look blurry. This prevents me from logging on. I have tried rebooting using other modes explained online with no success. Any ideas on the issue?
Update (04/05/2021)
Is there a simple fix for a replacement part or is it time to just retire this computer? If it’s time for replacement, I’m totally fine (have backups from time machine) but before I get rid of it how do I best clean the computer of personal info before it gets recycled, since I cannot access any info right now?
Add a comment
1 Answer
Chosen Solution
Not good ;-{
Your GPU board has failed iMac Intel 27" EMC 2429 Radeon HD 6770M Graphics Card
Replace a Radeon HD 6770M graphics card in a Model A1312 Mid 2011 27" iMac. Image
Product
$99.99
5 Comments:
by
@Chris Radcliffe - Some people have managed to cook the board to get a bit more live out of your system. Replacing it is getting hard as these board are no longer being made.
by
Thanks for the advice. I have seen some discussions on that but I think I’ll retire it. Is there a way to clean computer of personal info before I recycle?
by
@Chris Radcliffe - You should still be able to boot up in Target Disk Mode. See if you can you should see a FireWire or Thunderbolt Icon on your screen if you do then you should be able to connect your system to a second Mac to copy off your system and properly wipe down the drive so nothing is recoverable.
Reference: Understanding the Applications for Target Disk Mode
If that won't work then you can remove the drive and use a 3.5" SATA to USB case to hold your drive to then copy stuff off or even use your drive as a backup.
by
Great! Thanks again!
by
Add a comment
Add your answer
Chris Radcliffe will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 51
Past 30 Days: 1,177
All Time: 1,387
