A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
88 Questions View all
Pro Controller Seemingly Dead
Hello everyone, this is my first time here so please forgive me for any errors. Recently I noticed that my pro controller has been acting up with the minus button not working, and so I wanted to investigate what is wrong with it. Upon taking the board out with those buttons and testing, when putting it back together I noticed that the controller would not turn on unless it was plugged into a usb-c cable, which was odd. During this stage, when plugging it in it would give a quick orange light flash, indicating that it was charging, then immediately turn off. The controller could still connect to the switch while plugged in. Somehow, someway after that the controller would not turn on at all, even when plugged in. This is definitely something I could have caused, but I have no clue what I could have done that caused this.
I am lucky to have a second pro controller I can use to test the components, so here is what I was able to figure out:
  • The battery from the broken pro controller still works
  • The face buttons and ribbon cable are still working, but are not necessary for the controller to turn on.
I don’t know if I can edit this post but if I can I will write down more here as I figure out what is wrong.
The only thing I can think of is that something on the board shorted as I was taking it apart, or that the rumble motors are required to be connected for the controller to turn on, since right now they are disconnected. I saw in another thread to use a multimeter to test some of the components, I’m pretty inexperienced with one so if that is a test I need to do it would help if I could have layman’s directions. I really don’t know what can be causing this and I hope I can get some guidance to get it back up and running.
Add a comment
1 Answer
youll have to educate your self a little bit on multimeter settings and what to test for on diodes, resistors and capacitors.
i would recommend combing the board for any SMALL SMD components that may have been knocked off by accident. they can be VERY easy to miss but typically youre looking for 2 solder pads that are empty.
this is a good example of this
https://raspberrypi.stackexchange.com/qu...
2 Comments:
Sorry for such a late response, I don't see anything on the board that has been knocked off. Here's an imgur link in case you might be able to see something I missed: https://imgur.com/a/Y1I8oyP
In the meantime I'm going to do my research on how to test the components and how to use the multimeter properly to do such. Thank you so much for the help!
by
no worries m8, thanks for the picture. from what i can see its hard to tell if the smaller components are there or not. but from the looks it looks ok
by
Add a comment
Add your answer
Matt E will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 195
