Why is my 2015 MacBook overheating with no load?
I have a fresh install of Big Sur, and at room temperature, doing little more than having Safari open, I get a temperature warning, followed by the laptop going to sleep to cool down. According to the Intel power gadget, the temperature never rises above 55C or so. When it doesn’t sleep, the machine is running super slowly, unless I try to run it in the freezer, in which case it snaps to life. Any ideas?
UPDATE: Added photos:
When the first warning appears:
And a few minutes later when the second warning appears:
2 Comments
Lets see if we can get a better picture on whats getting hot as well as why your system is not cooling properly. Install this app TG Pro you will likely want the full version here as you'll need the logging function to track things if you can't get a snapshot of the main window before the system shuts down. Post either here for us to see Adding images to an existing question
by Dan
Added images of TGPro when the first warning appears as well as when the second one appears. The laptop goes to sleep shortly after the second warning.
by tai att
