Why will my laptop not power on?
I accidentally dropped my laptop and the screen started glitching. I turned it off then right back on and it was fine. I then closed the my laptop and when I went to use it again it would no longer turn on. I’ve plugged it up and nothing. No lights come on whatsoever.
Add a comment
1 Answer
When you connect the power do you see a light indicating that it is charging. Usually blue or amber? Steps to try
1: Try from different outlet
2: Try from different power connector (If possible)
3: Clean power input with alcohol with qutip and try again
4: If under warranty you may need to send it in. If not under warranty you may need to open laptop inners and check that power connect is connected to motherboard.
Add a comment
Add your answer
stephyrm1985 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 72
