Signal pinout for LCD panel
Hello,
I’m in need of some information. I have a Hitachi LCD panel with 15pin internal connector for signal and 4 pin for power supply to the CFL backlight lamp.
On the datasheed it says that the communitacion type is VGA.
This is the model:
From the datasheet of the panel, I’ve found the table with signals for the connector:
The question is how can I connect a regular monitor (presumably with VGA cable) to the signal cable?
A bit of a backstory - the panel is from an industrial machine and it’s broken. It’s old model, obsolete from the manufactorer support and spare parts. However, I found old stock of 2 panels, changed them, everything worked for 2 months and they broke again - they backlight lamps burnout or something else.
I’m trying to replace the panel with a common PC monitor. Is there a way for me to make a “converter” cable? In what configuration should I connect the pins?
Would really appreciate any help on the topic!
