PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Questions View all
On PS4 DS: Left stick and L2 overlap each other
Whenever I press L2 the left stick claims to move forward! How can I fix this?
I initially thought that it was a dirt issue - that through whatever side effect the system would pick up soft forward motion on the left stick. After cleaning and no change in behavior I looked at the USB HID logs: In center position the left stick (ABS_Y) is at jitterung around 108 109 110 (the value range is 0…255) and the L2 - which is identified as ABS_Z is at zero.
Now If I swiftly press L2 the follow happens:
Event: time 1615892603.331589, -------------- SYN_REPORT ------------
Event: time 1615892603.335600, type 3 (EV_ABS), code 1 (ABS_Y), value 86
Event: time 1615892603.335600, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90007
Event: time 1615892603.335600, type 1 (EV_KEY), code 312 (BTN_TL2), value 1
Event: time 1615892603.335600, type 3 (EV_ABS), code 2 (ABS_Z), value 13
Event: time 1615892603.335600, -------------- SYN_REPORT ------------
Event: time 1615892603.339612, type 3 (EV_ABS), code 1 (ABS_Y), value 84
Event: time 1615892603.339612, type 3 (EV_ABS), code 2 (ABS_Z), value 19
Event: time 1615892603.339612, -------------- SYN_REPORT ------------
Event: time 1615892603.343615, type 3 (EV_ABS), code 1 (ABS_Y), value 81
Event: time 1615892603.343615, type 3 (EV_ABS), code 2 (ABS_Z), value 24
Event: time 1615892603.343615, -------------- SYN_REPORT ------------
Event: time 1615892603.347616, type 3 (EV_ABS), code 1 (ABS_Y), value 79
Event: time 1615892603.347616, type 3 (EV_ABS), code 2 (ABS_Z), value 31
Event: time 1615892603.347616, -------------- SYN_REPORT ------------
Event: time 1615892603.351593, type 3 (EV_ABS), code 1 (ABS_Y), value 82
Event: time 1615892603.351593, type 3 (EV_ABS), code 2 (ABS_Z), value 39
Event: time 1615892603.351593, -------------- SYN_REPORT ------------
Event: time 1615892603.355607, type 3 (EV_ABS), code 1 (ABS_Y), value 81
Event: time 1615892603.355607, type 3 (EV_ABS), code 2 (ABS_Z), value 41
Event: time 1615892603.355607, -------------- SYN_REPORT ------------
Event: time 1615892603.359583, type 3 (EV_ABS), code 1 (ABS_Y), value 79
Event: time 1615892603.359583, type 3 (EV_ABS), code 2 (ABS_Z), value 56
Event: time 1615892603.359583, -------------- SYN_REPORT ------------
Event: time 1615892603.363586, type 3 (EV_ABS), code 1 (ABS_Y), value 75
Event: time 1615892603.363586, type 3 (EV_ABS), code 2 (ABS_Z), value 64
Event: time 1615892603.363586, -------------- SYN_REPORT ------------
Event: time 1615892603.367586, type 3 (EV_ABS), code 2 (ABS_Z), value 70
Event: time 1615892603.367586, -------------- SYN_REPORT ------------
Event: time 1615892603.371578, type 3 (EV_ABS), code 1 (ABS_Y), value 76
Event: time 1615892603.371578, type 3 (EV_ABS), code 2 (ABS_Z), value 79
Event: time 1615892603.371578, -------------- SYN_REPORT ------------
Event: time 1615892603.375607, type 3 (EV_ABS), code 2 (ABS_Z), value 86
Event: time 1615892603.375607, -------------- SYN_REPORT ------------
Event: time 1615892603.379609, type 3 (EV_ABS), code 1 (ABS_Y), value 71
Event: time 1615892603.379609, type 3 (EV_ABS), code 2 (ABS_Z), value 95
Event: time 1615892603.379609, -------------- SYN_REPORT ------------
Event: time 1615892603.383609, type 3 (EV_ABS), code 2 (ABS_Z), value 106
Event: time 1615892603.383609, -------------- SYN_REPORT ------------
Event: time 1615892603.387606, type 3 (EV_ABS), code 1 (ABS_Y), value 69
Event: time 1615892603.387606, type 3 (EV_ABS), code 2 (ABS_Z), value 114
Event: time 1615892603.387606, -------------- SYN_REPORT ------------
Event: time 1615892603.391578, type 3 (EV_ABS), code 2 (ABS_Z), value 116
Event: time 1615892603.391578, -------------- SYN_REPORT ------------
Event: time 1615892603.395576, type 3 (EV_ABS), code 2 (ABS_Z), value 120
Event: time 1615892603.395576, -------------- SYN_REPORT ------------
Event: time 1615892603.399605, type 3 (EV_ABS), code 2 (ABS_Z), value 124
Event: time 1615892603.399605, -------------- SYN_REPORT ------------
Event: time 1615892603.403600, type 3 (EV_ABS), code 1 (ABS_Y), value 67
Event: time 1615892603.403600, type 3 (EV_ABS), code 2 (ABS_Z), value 128
Event: time 1615892603.403600, -------------- SYN_REPORT ------------
Event: time 1615892603.407572, type 3 (EV_ABS), code 1 (ABS_Y), value 65
Event: time 1615892603.407572, type 3 (EV_ABS), code 2 (ABS_Z), value 136
Event: time 1615892603.407572, -------------- SYN_REPORT ------------
Event: time 1615892603.411571, type 3 (EV_ABS), code 2 (ABS_Z), value 143
Event: time 1615892603.411571, -------------- SYN_REPORT ------------
Event: time 1615892603.415601, type 3 (EV_ABS), code 1 (ABS_Y), value 66
Event: time 1615892603.415601, type 3 (EV_ABS), code 2 (ABS_Z), value 151
Event: time 1615892603.415601, -------------- SYN_REPORT ------------
Event: time 1615892603.419595, type 3 (EV_ABS), code 1 (ABS_Y), value 63
Event: time 1615892603.419595, type 3 (EV_ABS), code 2 (ABS_Z), value 155
Event: time 1615892603.419595, -------------- SYN_REPORT ------------
Event: time 1615892603.423598, type 3 (EV_ABS), code 1 (ABS_Y), value 61
Event: time 1615892603.423598, type 3 (EV_ABS), code 2 (ABS_Z), value 159
Event: time 1615892603.423598, -------------- SYN_REPORT ------------
Event: time 1615892603.427568, type 3 (EV_ABS), code 1 (ABS_Y), value 58
Event: time 1615892603.427568, type 3 (EV_ABS), code 2 (ABS_Z), value 166
Event: time 1615892603.427568, -------------- SYN_REPORT ------------
Event: time 1615892603.431566, type 3 (EV_ABS), code 1 (ABS_Y), value 59
Event: time 1615892603.431566, type 3 (EV_ABS), code 2 (ABS_Z), value 172
Event: time 1615892603.431566, -------------- SYN_REPORT ------------
Event: time 1615892603.435592, type 3 (EV_ABS), code 1 (ABS_Y), value 57
Event: time 1615892603.435592, type 3 (EV_ABS), code 2 (ABS_Z), value 181
Event: time 1615892603.435592, -------------- SYN_REPORT ------------
Event: time 1615892603.439571, type 3 (EV_ABS), code 1 (ABS_Y), value 55
Event: time 1615892603.439571, type 3 (EV_ABS), code 2 (ABS_Z), value 187
Event: time 1615892603.439571, -------------- SYN_REPORT ------------
Event: time 1615892603.443588, type 3 (EV_ABS), code 1 (ABS_Y), value 49
Event: time 1615892603.443588, type 3 (EV_ABS), code 2 (ABS_Z), value 197
Event: time 1615892603.443588, -------------- SYN_REPORT ------------
Event: time 1615892603.447587, type 3 (EV_ABS), code 1 (ABS_Y), value 48
Event: time 1615892603.447587, type 3 (EV_ABS), code 2 (ABS_Z), value 206
Event: time 1615892603.447587, -------------- SYN_REPORT ------------
Event: time 1615892603.451538, type 3 (EV_ABS), code 1 (ABS_Y), value 46
Event: time 1615892603.451538, type 3 (EV_ABS), code 2 (ABS_Z), value 212
Event: time 1615892603.451538, -------------- SYN_REPORT ------------
Event: time 1615892603.455584, type 3 (EV_ABS), code 1 (ABS_Y), value 43
Event: time 1615892603.455584, type 3 (EV_ABS), code 2 (ABS_Z), value 221
Event: time 1615892603.455584, -------------- SYN_REPORT ------------
Event: time 1615892603.459559, type 3 (EV_ABS), code 1 (ABS_Y), value 38
Event: time 1615892603.459559, type 3 (EV_ABS), code 2 (ABS_Z), value 231
Event: time 1615892603.459559, -------------- SYN_REPORT ------------
Event: time 1615892603.463560, type 3 (EV_ABS), code 1 (ABS_Y), value 31
Event: time 1615892603.463560, type 3 (EV_ABS), code 2 (ABS_Z), value 244
Event: time 1615892603.463560, -------------- SYN_REPORT ------------
Event: time 1615892603.467550, type 3 (EV_ABS), code 1 (ABS_Y), value 25
Event: time 1615892603.467550, type 3 (EV_ABS), code 2 (ABS_Z), value 255
Event: time 1615892603.467550, -------------- SYN_REPORT ------------
Event: time 1615892603.471558, type 3 (EV_ABS), code 1 (ABS_Y), value 17
Event: time 1615892603.471558, -------------- SYN_REPORT ------------
Event: time 1615892603.475574, type 3 (EV_ABS), code 1 (ABS_Y), value 8
Event: time 1615892603.475574, -------------- SYN_REPORT ------------
Event: time 1615892603.479584, type 3 (EV_ABS), code 1 (ABS_Y), value 0
ABS_Y first jumps down to 80 then even further, only if I simultaneously wiggle the stick I can counter this effect a bit. In the scenario above It ends with ABS_Y being 0, so the stick is claimed to be at maximum upwards position.
Is something miswired?
Add a comment
1 Answer
Hi,
This problem is usually cause by dirt in the potentiometer that is responsible for up and down movement on the joystick. If cleaning it doesn't work, it probably need to be replace.
This video should help you out to do your repair : https://youtu.be/RcIza5Zz8qY
Add a comment
Add your answer
Andreas Pokorny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 108
