Screen problem in MacBook 2015 retina (vertical lines)
Hi guys. These lines have a mind of there own. Flickers and fades. When plugged into an external monitor it’s fine.
Any idea how to fix?
If your external doesn't encounter the issue that points to the internal display has a problem. Here’s the guide to replace it MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement
Finding a good display will be hard as people who own these systems are not turning them in as they are still using them! I have two and you’ll need to kill me to get them as I’m very dependent on them. Still the best MacBook Pro Apple has produced even with its flaws and limitations.
Geez! … Is there any compatible LCD panel without full assembly?
I can put it in without front glass if needed.
From my experience - using Windows based laptops - it’s always possible to buy compatible LCD panel to fit in with some modding, gluing or DIY.
@lex49 - This is the Apple world! Things are a bit different. There is no cover glass in this display. Here''s a teardown to give you an idea what's involved MacBook Pro Retina Display Teardown. You might be able to find a raw LCD panel but its a bit of work to fit it and get to work cleanly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 373
