Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Screen/display remains black - though phone is working!
I (perhaps foolishly!) decided to replace the battery and back cover on my trustworthy 3GS. I did this circa two-three months ago. It went without hitch apart from the camera not working (I couldn't get the camera in the holder, with connecter attached to logic board so gave up).
Anyway, I decided I needed the camera back (as I use it a lot for work as I was sick of batteries going on normal camera). So I took it apart again.
Now my screen won't work. It is black, and you cannot see anything on it under a bright light. However the alarm clock is still going off and it makes a noise when plugged to a charger/laptop. I can still add stuff etc through the mac to the iPhone, and back it up etc - just nothing on the actual screen of the phone!
I have tried the hard reset numerous times, I have taken it apart several times to check the connections and to take the logic board off to "drain" before reconnecting (I couldn't turn it off before taking apart and someone suggested on here that there may be a safety feature if disconnected while it was still on).
Any ideas...? Totally baffled.
Score -1
Add a comment
1 Answer
Chosen Solution
I'd have thought that if you have tried everything else then you need a new LCD. Sorry. The only way to check this is true before purchasing a new part is to borrow a friends 3gs and swap screens.
Score 2
2 Comments:
Thanks - no apologies required - would rather know how to fix it!! :D Sadly OH is a little more up to date than me with the 4S...perhaps I should get more uptodate!
by
resale is pretty good on these..esp if it's just a black screen. Sell it on ebay and get some money toward an upgrade?
by
Add a comment
Add your answer
Clare will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 500
