LG WF-T1072TP not draining with heavy load
Our top loader drains OK with a small load but with heavier beach towels (which is probably close or more than the 10.5kg load maximum), the pump runs but doesn't drain. If we remove the heavy, wet, towels, it drains. The same loads used to work w/o a problem for many years. No error code displayed. Could the drum support be so worn that the drain is effectively plugged with a heavy load?
Score
0
