Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Replaced HDD with SSD and now fan is going crazy
Replaced HDD with SSD and now fan is going crazy, I did attach the temp sensor to it to that bought from here on iFixit. Haven’t put the lcd back on all the way because of this. Can someone help?
Add a comment
1 Answer
Your systems SMC is looking for the thermal sensors within the display assembly which is why your system fan is running hard and your CPU is down clocked as well to protect it from overheating.
So carefully plug in your display cables that should resolve things. If not run the onboard diagnostics. Restart your system and press the D key to enter.
Reference: Mac startup key combinations
Let us know what you get for an error.
Add a comment
Add your answer
Austin Flatt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 42
