Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
Wite spots on iPhone screen after screen replacement?
Hello.
I have just done a screen replacement on an iPhone 8 but afterwards, there are some white marks on the screen as shown in the photos above. Where did these marks come from and how do I get rid of them?
You will be able to see the images of the marks below
Thanks
Score 2
1 Comment
Did You put pressure on the screen
by
Add a comment
1 Answer
Chosen Solution
This could mean that something isn’t assembled correctly inside of the phone and is pressing against your display panel. You can easily test this by opening the phone again and to not press it into the case. If you still see white dots it probably means that your display got damaged during installation or that it was damaged before installation.
I noticed something similar on an iPhone 7 Plus I worked on where the display flex cable was not correctly routed under the shield of the screen, causing some pressure on the screen resulting in similar white dots when touching on the display. Take a look at the screen replacement guide as of step 34 to double check your cable is routed properly. I’m saying this because the white spots in your pictures happen to match the placement of the ribbon cables.
Did you test the screen before fully assembling the phone again?
Score 1
3 Comments:
I agree with u
by
I fixed it. It was because there was a screw missing from the display where the small silver chipset for the screen goes. I managed to get another screw and screw the metal back plate fully onto the display so it all works now.
Thanks for the help
by
@eisah Awesome! Glad it was something small like that ;-) don't forget to mark this answer as the solution then.
by
Add a comment
Add your answer
Eisah Sharif will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 76
All Time: 1,583
