Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
Can A Shorted 8 Plus Proximity Flex Be Salvaged?
After a screen replacement on the 8 plus and shorting out the proximity flex by not putting the black sticker on correctly covering the gold plates, can I save the flex cable by re-alligning the black sticker, connecting it back to motherboard, would this then fix it or is my only answer buying a replacement proxy flex? Everything works apart from earpiece speaker
Score 1
1 Comment
This is how much I covered the gold plates with the black sticker, it covered all the gold plates but still shorted. [image|2316387]
by
Add a comment
Chosen Solution
It depends, if the short didn’t damage the flex cable itself you can get away by just replacing the earpiece. If you notice after replacing the earpiece speaker that the earpiece speaker still isn’t working you’ll have to replace the flex cable.
You can re-use the tape that came with it or use something like Kapton tape to isolate the connections like described in the repair guide. Any short circuit can be fixed :-)
iPhone 8 Plus Front Camera and Sensor Cable Replacement
Score 2
2 Comments:
Great answer, thank you.
I'll need to be more careful with alignment of the black sticker.. It's frustrating how this was designed.
by
I agree, this sticker is really not the best design. If you're using something like kapton tape you could also put it on the ribbon itself to ensure it's 100% covering the contact points.
by
Add a comment
Most of the time a short is permanent
Add a comment
Add your answer
Che Hayden will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 175
