The BLU Vivo series (BLU Vivo 11) entered into the 11th generation as BLU Vivo XI and BLU Vivo XI Plus smartphones are planned. The BLU Vivo XI Plus launch date was on August 16, 2018.
Wifi keeps disconnecting at random
I recently changed my internet service provider and since then I've had a problem with my phone disconnecting from the wifi but only my phone no other device in the house.
This happens seemingly at random and doesn't seem to have a obvious trigger.
Some of the time it will say the wifi is disabled other time it will say it's saved.
It would usually fix itself after I go into the settings and connect to the wifi again then it take a minute or so and refreshes as if I've turn wifi off and on, on my phone. Or sometimes it just connects back on its own after some time.
1 Comment
My WiFi keeps disconnecting and reconnecting on me
by
Add a comment
Most Helpful Answer
Hi @mylese0 ,
Have you checked the WiFi’s > Preferences at all?
Don’t know the phone and the user manual doesn’t show what the preferences are but with some phones there are preferences such as Keep Wi-Fi on during sleep (should be set to Always) or perhaps Wi-Fi optimization
Try the following and check if either one resolves the problem:
Wipe the cache partition and check if it now works OK
Start the phone in safe mode and check if the problem still occurs. If it doesn’t then a downloaded app is the cause of the problem. The trick is to find out which one. A downloaded app is one that you installed and was not already pre-installed on the phone when you first got it.
Score 1
1 Comment:
Wiping the chacha partition did decrease how often it happened for a while, but I wasn't a permanent fix.
I tired deleting some more recently installed apps and that didn't work I imagine it must be a older app affecting my new internet. Or a update to an app that started the problem... I'm still trying to determine which app may be causing the problem if any are.
by
Add a comment
If you recently changed ISPs and only your phone is affected, try first deleting your WiFi connection in your phone and then resetting your router.
Your phone's WiFi settings should have an option to "forget” the connection and start over.
If this doesn't work, try entering your router's firmware from a device besides your phone. Open a browser and type the router's IP address (usually 192.168.1.254 or 192.168.1.1, but the info should be in the router's documentation) in the address bar. Poke around the interface until you find an option to reset the router back to factory defaults.
1 Comment:
Thank you for the response, unfortunately neither of these methods worked.
I've edited my question to add images but unfortunately I have no new info, except for a theory that it only happens while I'm using the Internet, though I have no proof as I'm almost always using the internet when I'm on my phone.
by
Add a comment
Add your answer
MysticMylesZ will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 1,385
