Model No. A1367 / 8, 16, 32, or 64 GB capacity
No wifi
my ipod touch 4th gen will find the wifi and show that its connected but when i goto like my safari it tells me that safari cannot open homepage it want let me get into my app store either it just loads forever....... i neeed help and suggestions?????
Add a comment
1 Answer
Chosen Solution
tyler, have you tried the Apple solution first from here It does sound like a software issue more than a hardware one. "If you are using a public or commercial network that requires a login or subscription, see this article for more information.
Verify that you are selecting the correct network if you are in a location with multiple Wi-Fi networks.
Verify that the Wi-Fi network settings are correct. You can view and configure Wi-Fi settings using the following steps:
Tap Settings > Wi-Fi.
Locate the Wi-Fi network you are currently using and tap The right arrow button.
If you've verified that your settings are correct and the issue persists, try the following:
Tap "Forget this Network" to reset settings for this Wi-Fi network, including the password. Then try connecting to the network again.
Note: This can be useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
Reset network settings by tapping Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi address in Settings > General > About."
Score 1
Add a comment
Add your answer
tyler will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 908
