iPhone 7 home button not working after battery replacement, no "shake"
Just to add on, it does not say anything like "touch id fail" and I can change the "home button haptic to 1 2 or 3" but not feeling any shake when I press the button. " Samething, my finger prints are there but sensor don’t read my finger print(login screen won’t get in). It also does not have the “shake” feeling/ any response when I click on home button. Try adding new finger print will stuck on the image shown page without reading my finger print / having the “shake “ response that usually happen when adding finger print.
I did a battery replacement to my iphone 7. I turn the device off prior and disconnect the battery prior to begin. What I did is unscrew the tapic engine and fold it halfway then remove the battery. I did not disconnect the screen or touch screen cable all in the whole process. The screen was intact the whole time. However after I put everything back together, the screen works perfect but my home button is not working. ++++No tear or rips either. Any idea on how to fix this issue please? Thank you
