Why does my monitor lose signal when gaming?
So when I’m gaming, my monitor loses signal however my pc keeps running. In order to fix the problem I have to restart my PC. I have tried replacing my GPU and PSU so it’s a pretty good assumption that it isn’t one of these two components causing the issue. Also to note, this happens more often when I am running a more powerful game, and it also happens more often on a hot day - to suggest that the stem of the problem is something to do with overheating. This problem has been ongoing for a long time so any help would be much appreciated.
2 Comments
@anjas what make and model GPU are you using and what game are you having issues with? You update your BIOS etc?
by oldturkey03
I have the same problem
Most likely a motherboard issue
But for me personally
It probably had to do with my cpu overheating
Because whenever i take the side panel off
The problem stops
If you have solved the issue
Perhaps you could enlighten me on what exactly caused it for you and how you fixed it
by OmniGod Goku
