A1398 - New Simplo battery - System dead after 3 days.
This is sounding awfully similar to what happened here: I changed my A1398 battery last week, with the iFixit kit
Everything went well then 3 days later the computer suddenly shuts down and stays dead. The battery is charging, a SMC reset shows the LED changing colour, it just won’t turn on. Disconnecting the battery doesn’t help.
I have to wait a few hours before being able to power it on again, only to see it die again after a couple minutes.
Would that be the battery that killed the logic board? I’m using an original magsafe charger.
Edit: I managed to boot it long enough to run CoconutBattery, before it died again. Actually a Simplo battery
I spun your issue to a new question as its not the same problem.
If you can see if you can get a snapshot of CoconutBattery so we can see what's happening. CoconutBattery post it here for us to see Adding images to an existing question
by Dan
Hi Dan and thank you for splitting my comment, sorry if it was not relevant to the other question.
I just added a few screenshots of what CoconutBattery shows
by Stephane
I now have access to an oscilloscope, and discovered voltage spikes when disconnecting and reconnecting, and expect similar when waking from sleep. My Mac's GPU died after waking from sleep on battery.
The original battery PCB is labelled Compeq, and includes a TI BQ20Z45 gas gauge chip. It idles at 2V, and "wakes up" by handshaking. The voltage spikes go up to 4.5V.
The fake battery PCB has an chip labelled A2169 A37061O01F instead of a TI. It's apparently a knockoff gas gauge. That battery idles at 12 V.
There's a third battery, labelled Dynapack, currently in my computer. I replaced the logic board, and the seller offered me a top case and battery for an extra $50. The Dynapack battery idles at 6.75V.
I tried moving the Compeq PCB from the known good (but swollen) battery to the new "Simplo" cells. It triggered an undervoltage PF flag, and I don't know the unseal code, to use Charlie Miller's code to clear the PF permanent failure. Thanks for warning me that iFixit batteries are also "Simplo".
by Peter Burkimsher
