Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Only restore on USB 1.1, Wont charge
I am trying to repair a water damaged Iphone.
I was getting various errors when trying to restore, Error 9 was the most common. I noticed that when I plugged it in the the computer, Windows would always give me an message to plug it into a USB 2.0 port. (port was 2.0) Then during restore it would always fail.
Anyway. I was able to finally restore after using a USB 1.1 hub.
Now the problem is that it won't charge. When I plug the phone into either a AC Charger or the computer, the Graphic changes to indicate that it is charging,but it does not charge. I was able to charge the same battery in another phone, so I know it is not a faulty battery.
I am suspecting that one connections in the USB has failed.
I have replaced the charging port assembly, and examined the internal plug (connecting Charging port to logic board) and it seems fine.
Any advice on where the problem may be. Thanks.
Score -1
Add a comment
1 Answer
Chosen Solution
take a look at oldturkey's answer here, it has a great picture attached of the charging fuse. This may be your problem... if it solves your problem please upvote his answer!
Score 4
4 Comments:
Does this look like it could be the problem? Is that a Fuse that is missing? Maybe a capacitor?
http://imgur.com/KXoKX
by
in short..yes. there is meant to be a little blue inductor/fuse there. You could try to replace it or join the 2 points with a blob of solder...this isn't the best choice as you have no fuse, but it will solve the problem.
by
Thanks, I will try that. What about this, its the same board. Looks like a slip of a screwdriver took this off. Is it a fuse, resistor or capacitor? Can I just join it? Hope you can see it.
http://imgur.com/a/av0XZ
by
take a look at this board.. I think you have another missing part there..oops with the screwdriver indeed! scroll down the page to the motherboard, click view huge..http://guide-images.ifixit.net/igi/hsa3H...
by
Add a comment
Add your answer
Awesome possum will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 447
