Only restore on USB 1.1, Wont charge
I am trying to repair a water damaged Iphone.
I was getting various errors when trying to restore, Error 9 was the most common. I noticed that when I plugged it in the the computer, Windows would always give me an message to plug it into a USB 2.0 port. (port was 2.0) Then during restore it would always fail.
Anyway. I was able to finally restore after using a USB 1.1 hub.
Now the problem is that it won't charge. When I plug the phone into either a AC Charger or the computer, the Graphic changes to indicate that it is charging,but it does not charge. I was able to charge the same battery in another phone, so I know it is not a faulty battery.
I am suspecting that one connections in the USB has failed.
I have replaced the charging port assembly, and examined the internal plug (connecting Charging port to logic board) and it seems fine.
Any advice on where the problem may be. Thanks.
